RCU Forums - View Single Post - Printing water transfer decals at home
Old 01-20-2012 | 12:55 PM
golf4two
Default RE: Printing water transfer decals at home
ORIGINAL: scale only 4 me
Looking at a couple pics on your flicker acct. It seams to me you've over-coated them,, that may be why they are pealing,, You only need a light coat to seal the ink to the decal film. If you coat it too heavy that coating could continue to shrink an pull the edges with it.
Good luck
Scale only has a good point about the coating. I printed mine on no-name brand decal paper from the plastic oriented hobby shop. Pinned the printed paper to a sheet of ceiling tile so it wouldn't wrinkle. Several mist coats of LustreCote (nitro plane) and let that dry for 48 hrs. Trimmed out decals. Cleaned Monocote with alchohol. Wet decals down and waited 'til they slid easily. Positioned then squegeed with one of those advertising phony cardboard credit cards you get in the mail. Cleaned up around the edges with moistened paper towel. Let them dry ONLY FOR ABOUT AN HOUR OR SO (or they'll most likely start lifting later). After about an hour (surface of decal is dry), I then ran the edges with BalsaRite for film to seal. Mine have been on for almost two years now.....no lifting even when cleaning up that nasty old Nitro fuel residue.
The flag is about 4X5, AD 4 wide. Others Futaba, Saito & club logo smaller. Stars and Pegasus are cut from 'Cote.
Not saying this is the best way, just that it has worked time and again for me. I've done this with six different planes.
Regards,
G42
ID:	1716598   Click image for larger version
ID:	1716599   Click image for larger version
