RE: Hall sensor question ?
If the gap between the sensor and magnet is close enough , (no more than .030") it should work fine. If you start getting high speed misfiring though, you will have to close the gap some more. I have tried alot of sensors and some work in a leaned over attitude while others don't. It depends on the minimum gauss rating in the operating specs for the particular hall sensor.
John
