ORIGINAL: 80sPattern
[Bryan,
Are you planning to come to the Classic get-together that Robert is hosting in May
Doug
Doug thanks for asking.
I do want to go, but I also want to practice the Novice Pattern Manuervers before I make a descision as I'm still trimming out my Kaos 40. Had a setback on my it but I think I found the problem. It was not able to get peak RPM after the last adjustment of down thrust. Turns out a small piece of plastic or something was blocking the passage at the high speedneedle. Must have got in there while I had the engine apart toport the sleeve.
I guess the saying is appropriate - Don't fix it if it aint broke.
Workhas kept me from having thetime to continue the trimming process. Hopefully tomorrow I will get to the field.
Bryan
