RCU Forums - View Single Post - ModelTech Mustang
Old 08-23-2002 | 12:18 AM
Richard L.'s Avatar
Richard L.
My Feedback: (24)
Default ModelTech Mustang
Just finished putting mine together. I'm not too crazy about the lack of wing dihedral either because this makes the plane less scale and unstable at low speed.
I had some problems with fit and finish:[list=1][*]The rear of the wing doesn't line up with the belly on the fuselage[*]The cowl doesn't blend in smoothly with the fuselage, even after careful trimming and sanding.[*]The axles on the retracts were bent at the wrong spot, so the wheels won't go into the wheel wells.[*]The bomb decals are just black circles. There are no fuses or sparks. I had to paint the fuses myself.[*]The supplied spinner is not a parabolic mustang spinner. I replaced it with a Tru Turn P-51 spinner.[/list=1]
This plane flies great and sounds great with a Saito 72 four stroke swinging a 13x6 prop. However, it tends to pitch up above half throttle with the gears up. I had to use some down trim on the elevator to keep it flying level. Contrary to what the ads say, this plane likes to land hot. On my maiden flight, I slowed it down to my usual landing speed, and it tip stalled. My Kyosho ME-109 is much easier to land. Nevertheless, it is still a great looking plane.
Here are some pictures of my Short-Fuse Sallee:
