RCU Forums - View Single Post - Transmitter?
Thread: Transmitter?
Old 01-21-2012 | 03:13 PM
  #47
HoundDog's Avatar
HoundDog
My Feedback: (49)
Default RE: Transmitter?
ORIGINAL: Gray Beard
I went with the A-9 too. I have a Futaba 9-C I have been using sense they first cme out. I upgraded from a Hitec 7. At the time th HT I had only could program 3 planes and that turned into a problem very fast. The 9 allowed me a lot of planes set up in one radio and a ot of room to grow/expand. I have had to use a match box on planes like 35% to 40% nut that isn't any big deal.
The Hitec A-9 is the radio I have been looking at in 2.4, I have my futaba set up for both 72 and 2.4 but my radio is getting a bit old. With the A-9 you are able to just go back and forth from 2.4 to 72 by changing out the module so you don't need to buy a thousand dollars worth of RXs all at one time to change over.
To date I haven't seen one radio problem with the Hitec or Futaba. No one can say that about JR/Spektrum. I can't afford to sacrifice a plane to a radio glitch or brown out. With the A-9 and Futaba system there is no reason to run the risk.
<span style="font-family: Comic Sans MS;"><span style="font-size: larger;"><span style="color: rgb(128, 0, 0);">Did U ever set up any FLT COND "Flight Condition" on the A-9 seem that U can Have 8 seperate setups on each of 30 airplanes ... As for problems with the A-9, I saw a plane fly away while using the A-9 Module in a Futaba 7 channel radio with a 7 channel HiTec receiver. But the plane was out about a half mile or better and had intermitent control till it flew way way away.</span></span></span>
<span style="font-family: Comic Sans MS;"><span style="font-size: larger;"><span style="color: rgb(128, 0, 0);">I have some strange things happen in my A-9 such as some programming had changed after I switched to another plane then came back to the first plane. I am paranoid about programing so ounce I get a program right I copy it and rename as a back-up. The backup was working properly but the original program was not. Coppied the back up to the original and that fixed it.</span></span></span>
