ORIGINAL: Square Nozzle
From experienced gained using ''Flexed and Flat'' on my F-22, don't spray on heavy wet coats. Apply almost dry. If you spray it to wet the flattening agent tends to settle away from the surface and you end up with a sorta glossy finish.
Very true John. Best way is to add extra reducer and then just 2 or 3
very light coats.
