RCU Forums - View Single Post - Aero Works P-51?
Old 01-22-2012 | 09:56 AM
  #946
Zeeb's Avatar
Zeeb
My Feedback: (41)
Default RE: Aero Works P-51?
ORIGINAL: miker49
i have finally glued the wing together.everything lines up ,locating dowels and wing bolts.went to start the air scoop and the rear of the scoop is 1/8'' wider on both sides.won't let the flaps come down .i plan on contacting aeroworks on mon to see if anyone else has had this problem.anyone here run into this?
Not seen that issue reported, one of the guys did have an issue with the air scoop fitting but it was an angle problem on an ARC version.
How wide is the scoop at the back corners? Mine is 7 3/4" straight across and the rear corners line up exactly with the corners formed by the trailing edge and the cutout for the flaps.
Check you locator pins on the front. Mine seemed to be short so I called AW and they said that sometimes in shipping the pins get knocked back into the wing. On one side all it took was a tiny bit of pressure and the pin slid back into the wing. On the other side, just a bit more pressure and in fact I was going to call it good and then it too broke loose. They should stick out the front of the wing about 1/2".
Zeeb is offline
