Climbing Flat Spin?
Do you mean spinning on the ground (tail-dragger I assume) and lifting into the air? Using lift from the spinning wing or thrust from the engine? Sounds cool if it can be done!!
I guess if you can do a climbing flat spin you can do a soft landing in a flat spin using the throttle. That would be cool too!!
