RE: Complete new CDI - website open
Yes...good that it is all working now.
I went back to the site initially and downloaded all the info once again(start fresh type of thing) and then did the tests.
I found one problem there. Monitor program to use with the CDI/TCI (Zip) this works fine. It has a curve already installed.
Problem comes when you download and install Example table to use with the monitor program (Zip) This has one complete column of data missing from the "Laptime [uSec] column and when one runs the monitor, this column is full of red exclamation marks. Whether this is an error or if one is supposed to put their own data in here prior to running, is not known. Either way, if you use this added data table, it does not work. One included with the monitor is fine, just have to change the curve. 30 degree advance at 1100 rpm and 4 degrees at 20,174 rpm is back-to-front to me.
I had no problems loading any changes I made to the curve back into the chip but John seemed to so it might be well worth watching the bottom line of the monitor program as you "upload" the new curve. It should show, if my memory is correct, 27 lines without any errors. John I think had 47 lines with some errors the first few times around. Not sure why this happened but finally he had success.
