i put a 1900kv turnigy motor in mine... runs good. i have 100a esc. you should use a 2000+kv motor
ORIGINAL: hotpod
I am building my second Hobby Lobby F-18.
The power is a 5000 mah 6 cell li-po 65C battery
the motor is a 1750Kv out-runner B3553
The speed controller is an 85 Amp ESC
The fan unit is 90MM
I have a spare castle creations 125 AMP ESC, I would like to replace the 85Amp ESC with the 125Amp speed controller.
Can anyone recommend a suitable motor to put in the 90MM fan unit, that will work with the 125 AMP ESC?
Thank you,
Walt (hotpod)
