RE: KMP OV-10 Bronco (refurb job)
I did a little more work this weekend. I made an access hatch for my switches fuel and air. I like everything in one place. Pic #1&2
Pic #3 &4 I got the left engine nounted. Everything is hooked up and ready for running. The right engine is too but no pics of that.
Pic #5 I had to redo the nose gear streering. The loops in teh cable is the stock setup however it binded when the wieght was on the gear. I put it back in the front but made a new pount right in front of the wheel. Now it moves ALOT easier
#6 thru8 The dowl rods for the wing were not very robust and a couple have broken just from normal use. So I used a 5/16 brass tube to cut the old pins out and put 5/16 pins in there place. Much stronger.
That's it for tonite, Later
Kelly
