RE: One way bearing always covered in oil
install a small o-ring around starter shaft on inside of starter plate(might need to cut a land in the aluminum back plate for o-ring. Also get some 80grit sandpaper and score the started shaft longitudinally(parallel to shaft) so the OWB has a more scuffed surface to "grab" That should help!
