RE: Glow Engine for 0% nitro?
I use FAI fuel in my Moki 1.80. Its usually in stock in my area, if not LHS will order it. I've also ran it in my ASP.61, and it runs good there too.. I've mixed my own before with Alky and Blendzal.. which is the same as they run in go-karts... I tried that to see if it was cheaper... I found costs to be slightly cheaper mixing it... but it was a neglible difference all things considered.. then the hobby shop started carrying it.. so its only about $10.00 a gallon ready-to-use.. it runs great.
As far as I know.. any high-compression engine of larger capacity uses FAI fuel well. SuperTigre2000-3000etc..series engines run very well on it too from what I understand. Larger bore MDS, and MVVS are in the category too.. if I'm not mistaken these are all "overbore", and definately high-compression engines.. dimensionally speaking of bore/stroke.
