RCU Forums - View Single Post - PWM help
Thread
PWM help
01-23-2012, 03:31 PM
1
Daddysharky
PWM help
Hi, I am new here and was wondering if someone might be able to help me with a question. My robot is homebuilt on wheels. I want to steer the bot with an electric window actuator (from a car) The motor turns much to fast to control so I want to use a PWM to slow it way down. My question is what size PWM do I need.(size =volt and amp rating)
Here are the specs of what I am using
~Sealed Lead-acid Batteries (12v12ah/20hr) 2 in series)
~Dorman 741-814 window actuator (Just the 12 volt motor!)
~DPDT switch wired for reverse to turn wheels left and right (servo attached to run remotely)
Links to products used:
http://www.energexbatteries.com/prod...ah%7B47%7D20hr
http://www.amazon.com/Dorman-741-814.../dp/B000E347L6
http://www.radioshack.com/product/in...ductId=2062530
Thanks for any advice. Also if you have a better less expensive approch I will take any suggestions.
Reply
Like
Daddysharky
View Public Profile
Send a private message to Daddysharky
Find More Posts by Daddysharky
View iTrader Profile
