RCU Forums - View Single Post - Top Flite Staggerwing
Old 01-25-2012 | 09:12 AM
  #1731
louie525
Default RE: Top Flite Staggerwing
Hello,
I want to thank everyone for posting pics and ideas! This thread is great for motivation!!! I am still working on mine since 2009? I bought the plane to be a father and son project; (Once upon a time Dad had an airport job and fueled up many SW'S!) The covering job was pretty rough and over 3 years in a box I could not get the winckles out so I have re-monokoted all of the balsa framing and plan to glue the center wing together and try to hide/eliminate the center seam. You guy's are right; you will have quite an investment between retracts, ARF, Moki 180 (NIB) plus servos - not to mention time! I hope to be under 20 pounds...good luck right!? Did anyone have issues with warps in the wings? I had to cut both the top and bottom TE sheeting on both lower wing halfs and re-glued on a slate table weighed down in an attempt to repair the warps. The warps are much improved but still have a slight bow. The top ailerons are bowed as well and I plan on building new ones. A twist can be repaired with monokote, but a bow type warp? Some guy's suggested to wet down the ailerons and try to remove bow that way...Never had much luck doing that. I will post some pictures of the construction shortly.
