ORIGINAL: SkyPilot101
Joe, if your using the China spark plugs, get rid of them & change to NGK.... China plugs are hit & miss. Gap with #11 Exacto blade, and check timming, approx 27 deg. BTDC
Thanks for the tip but, it came with CM6 and I just changed to a new one to be sure it was working well. Static test shows it's firing everytime.
I checked the timing and it's right on 28 deg. BTDC.
I found a tip on one of the other forums here and learned that the carb on the 20cc DLE may fit my engine. It's reported to be a very good carb and Tower sells them for a reasonable price. So, if this one doesn't work out Ihave an alternative.
RJ
