vee bottoms vs flat
Jim is exactly right, the flat bottoms plane out quicker, but can and will slip sidewise. I think you should consider the water you intend to fly off of. If it is usually smoothe, flat bottoms will be ok, but if is a bit choppy you will want the vee bottoms to cushion the shock of the waves............Seaplane
