RE: Saito FA 45 Prop Driver Removal - Help
The correct timing position is with the crankshaft at top dead center and the mark on the cam straight down.
Double check after assembly that the rocker arms are parrallel with each other at both top dead center positions of the crankshaft. (Compression & overlap)
