ORIGINAL: wyo69cowboy
I put (2) 15 minute flights on my Reactor and put back in over 3000mah; however, I don't think I was topped off before those flights. That plane also has 4 aileron servos, so I have a little more draw than the average 50cc setup (all digital on the flying surfaces). Weather looks good for tomorrow; I'm hoping to get a few flights in and will check usage again on the single pack with a full charge.
thanks...i currently have a 5200 Li Ion in one 50cc and 2 2300 Li Ions in another... Fully charged they read about 8.42 volts, and after a days flying, they rarely go under 8 volts... so i think ill be fine with a 3600 . in once 50cc and two 2100s in the other .. Im scared to use a single 2300 battery... the drop of in LiFe batteries is steep, there no warning from what i heard... you can do a check and it will read 6.6 then in the middle of a flight it can die abruptly ......
http://www.hobbyking.com/hobbyking/s...ePo4_Pack.html
