RCU Forums - View Single Post - Trim Sheet Usage Questions
Old 01-27-2012 | 01:14 PM
MTK
Default RE: Trim Sheet Usage Questions
ORIGINAL: wingnutEOD
<p class=''MsoNormal'' style=''margin: 0in 0in 10pt''><span style=''line-height: 115%; font-family: 'Arial','sans-serif'; font-size: 9pt''>Lo All,
I am a novice RC pilot looking to get into flying pattern as a means to gain/hone my flying skills. During my research I've read about using various maneuvers to help determine the required adjustments to an airframe that result in neutrally stable flight characteristics in all flight attitudes. (Trim sheet maneuvers and adjustments). What I have not found is an explanation or example/case study of actually using this method. This gives rise to a couple of questions for me:
1. At what throttle setting(s) am I flying these maneuvers? If I were to mechanically trim for SaL flight at 50% throttle, then at 51% to 100% I would have positive VS flight (not SaL anymore).
2. Is going through the trim sheet an iterative process? ie. After trimming for SaL flight you are to adjust the CG via one of two maneuvers. This CG change results in a different trim requirement for SaL flight than before, so do I go back and start over with the new CG position?
I am highly interested in any input the community has on this topic. I look forward to your replies.<o></o></span></p>
I see you live in Georgia....You have several very good guys out your way. Emory Schroeder is one....Chris Hinson (Mr Extreme Flight) is another
Not sure where exactly Glenville is but if it's close to Mack Hodges field (home of the SEFF) definitely give Mack a visit.
Your best bet at getting really good examples of what you seek is to actually have experience guiding you. FWIW2U
