RCU Forums - View Single Post - Aeroworks Quality
Old 01-28-2012 | 08:03 AM
flytreetimes
Default RE: Aeroworks Quality
I certainly would put Aeroworks well above others like Redwing/ Goldwing in build quality. A fellow flyer purchased an S Bach 50cc, its undercarriage litterly fell apart, destroyed the entire underside of the fuselage on his second glass smooth landing. It came out twice more before he actually cut out all the crap wood and built his own from quality aircraft ply. Each of three times it took out a $80 CF prop too!
I discovered the "hot melt" only after my stupid crash, the joints pulled apart down one side of the fusleage on the Extra 300. i was able to scrape the glue off and push everything back into place, replacing only some sheeting on fuse side and reinforcing the undercarriage mounts. It likely would have lasted forever except for my stupid pilot error.
As I stated before, the only sore spot is the aluminum LG, it should come with the CF stuff, the aluminum is all but useless. Even on perfect landings, it has bent 5 out of 6 times. FWIWflytreetimes
