RCU Forums - View Single Post - Pattern Rules Proposals
Old 01-29-2012 | 09:59 PM
  #179
rix
Default RE: Pattern Rules Proposals
ORIGINAL: nonstoprc
ORIGINAL: rix
ORIGINAL: nonstoprc
rtx,
Do you mind post some info on your plane? Is it way over-weight?
I went through all of this on another thread somewhere I think, but, I am flying a Vanquish (which I really like...allot) using all stock stuff and less expensive zippy 5000mAh 25c batteries, a redundant Rx power system with two 350mAh batteries, dual regulator (Power box 12), an APC 20.5x14 prop an arming switch, and a Himax 210 motor, I came out at 5100. That’s cutting it close for attending the nats in Advanced so I went out and spent more money on lighter packs which brought me down to 4998. Comfortable for Advanced this year but next year when I move to Masters I am too close for comfort again and will be forced into an elaborate set of choices and or expense, for example:
1) Make my equipment less safe by pulling out the arming switch, removing the redundancy system and or replace it with the a slightly lighter system such as using the flight packs for redundancy and or remove an Rx switch altogether and only use a regulator, or purchase expensive HV servos so I will not even need a regulator.
2) Pull out my wires from the elevator servos and let the two share a common pos and neg pair of wires too lose weight and remove my redundancy their in the event one of those pos and neg wires chafe and or the one cable pulls from the receiver leaving me with no Elevator control at all. I guess I could also take the dremel to my really nice airframe and start gutting it in strategic places.
3) Drop my sexy wheel pants.
4) Replace my $15 prop with a $90 one
5) Replace my $4 spinner with a $130 one
6) Replace my really nice CF landing gear that came with the kit with a set of $40 to $80 lighter ones.
7) Replace my $279 Himax motor with a $500 to $800 lighter one
8) Replace my really nice Futaba digital and BLS servos with HV ones so I can remove the regulator altogether.
9) Continue to purchase more expensive flight packs.
Anyway, these are my experiences and choices, currently.
rtx,
One of the two 350mAh batteries could be replaced by a smaller pack as you probably only need 50mah per flight.
Thunder Power's 125mah 1s (part# TP125-1SPL25UM) weighs only 3.4 grams (at $7 per piece). Two of these will be 6.8g. If your current 350mah is TP, it is 22 grams. A saving of 15 grams after replacement and you still have 250 + 150 = 400 mah of capacity. I am currently flying with a single 250mah TP at 17 grams for every 4 flights. Two of 250mah will give me 8 flights.
Also, I am using the same GP plastic spinner with the lighter alum backplate as you are. It weighs 4oz and I am thinking drilling some lighting holes on the backplate. Mejzlik also makes very nice-looking and super light carbon fiber spinners for E pattern. DA might carry them.
Lastly, if you are using steel bolts to secure the motor, consider replace them with titanium ones to save half of the weight.
I am using TP 350's and they come out around 46 grams together as a set with the velcro and so forth. I was actually thinking of going with a little more next time, but perhaps I should re-think it. I sliced a good portion of the cone off of the spinner for additional airflow to the motor, ESC and batteries and all of that comes out to 60grams including the bolts and so forth. Where are you getting the titanium bolts?
