RCU Forums - View Single Post - multi prop control
Old 01-30-2012 | 07:05 AM
Bax
Default RE: multi prop control
You don't need the multiprop function to do what you want. The system can easily control two engines with the programming it already has. You need to use mixers, and can control either or both engines from the throttle stick. You have to write down exactly how you want the controls to function, and then make a programming flow chart...that will make it easy to visualize what you need to do.
