<span style="font-size: smaller">ORIGINAL: vasek
First time working with full HV digi system (Hitec)
I have a HPP-21 servo programmer and have MX22 Tx (Hitec module) with lot of the same program
functions as servo programming (like servo reverse, end points, etc.)
What's preferable? Programming the servo via HPP-21 of programming the Tx?
What are the advantages/ setbacks of each one? Thanks, V.</span>
Programming Digital servo via the programmer is to be preferred as provides settings,
such as adjusting Deadband and other adjustmentswithout loss of latency orresponse.
Please refer to
Using the TX requires unequal travel set points
<span style="font-size: smaller">to garner equal surface deflections; accordingly your model may exhibit a more sensitive feel in one direction
than the latter to compensate for the unequal travel arc of the servo arm(s)
</span>.
Using (TX) trims, offsets and curves skews the results
<span style="font-size: smaller">and ultimately leaves you with unequal travel volumes and speed of the surface in play.
</span>and sub section
"Servo - Digital & Brushless Servo, Programmers and Software" e.g.
<dt>
Digital Servo - Digital (aka FET) Servo & difference with Analogue Servo (PDF).
Digital Servo Instruction Videos - Programming with HFP-10
Digital Servo Programming FAQ - Center & End Point - Adjust to Match TX
D
igital Servo Programming FAQ - Center Point May Vary - Why & Correction </dt><dt>
Digital Servo - Burnout. Cause & Prevention </dt><dt>
Digital Servo - Delayed or Slow Centering at Start up #01 </dt><dt>
Digital Servo - High Resolution & Jitter - Why & DIY Cure #02 </dt><dt>
Digital Servo - HSR (Robotic) Servo. Do Not Use for Acro or Standard Purposes. </dt><dt>
Digital Servo - Stop the Jitter of High Resolution Servo at center </dt><dt>
Digital Servo - "Y" together without problem / jitter
Hitec - Digital Servo - Resolution & Driving Frequency - Frame Rates,. </dt><dt>
Hitec - Digital Servo Programming Instruction 7XXX 50XX Manual.pdf
and more under
"Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
Alan T. </dt>
