RCU Forums - View Single Post - Glue question
Thread: Glue question
Old 08-27-2003 | 02:28 PM
FLYBOY's Avatar
FLYBOY
Default Glue question
Most people end up using a combination of all the glues. I have a whole drawer full. Different epoxies, CAs and wood glues. They all have different purposes for different outcomes. All are stronger than the wood they are bonding. Just depends on the use. Epoxies are great for center sections, firewalls, gear blocks, putting on the tail, white glues make good balsa to balsa glue or I use it to double glue joints I have glued with CA. The CA is what I build with. I put just about everything together with CA and then use the others to hold it. Just a spot of CA on the ribs, then white glue to hold them and such. Just some examples.
