RE: Top Flite 1/7 P-51 Build
It fits. its a dubro 12 oz tank. Just curious how everyone is mounting there fuel tank. Are you guys building a rail to strap the tank too or just shoving it in the open area?
Oh stupid me. I was trying to cut the rudder push rod shorter while it is already attached and installed in the plane. when I did that - one end ( the end that is attached to the dual connector and rudder) took off right when I cut it in two. the plastic dual pushrod that is attached to the tail gear broke in two. I am so upset. Luckly, I haven't installed the lower cover behind the radiator scoop so I still have access to the inside. Is there a TOOL that I can attach to the push rod so that I can finger twist it?
