RCU Forums - View Single Post - Making Some Progress... I'm slow...
Old 02-01-2012 | 06:55 AM
SteveR3750
Default RE: Making Some Progress... I'm slow...
Still Moving Slow, but nonetheless making some progress. I've managed to cover the Horizontal Stab and the Tail Fin. All Control Surfaces are now hinged, and in place with CA type Hinges, rather than being taped in place.. . Control Horns are installed and pushrods are connected. I painted the cowl and the landing gear using the Testors Gloss Yellow in the Spray Can. #1214. The "N" number Decals that came with the Kit just were not going to stay in place. I ended up tracing the outline of the numbers with a fine point Sharpie marker and then using a Sharpie Magnum Permanent Marker colored in or painted the numbers directly on the covering. Its not perfect, but they wont fly off the first time it flies...
Time to order another roll of Solartex so I can cover the fuselage....
ID:	1721949   Click image for larger version
ID:	1721950   Click image for larger version
