RE: 3 different Dual Rate at 2Point Switch
Three rates are on one switch....basic rate, and two that you set in the rates screen. Normally, one position is the rate your control surface has normally, and then two other rates are used to reduce throws. The AFR is where you set the zero-change position, and you then set the switch to "off-on-off" for the second rate, and "off-off-on" for the third rate.
