RE: Composite ARF Tucano Build
Why Jan??
My Tucano has had heaps of flights and is perfectly balanced, rotation is a non event and landings are just sweet, why would you want to move away from factory specs is it works!!! If you are so convinced that YOU need the 12 oz then do the cg as per factory then stick the 12 oz on and then do your maiden flight .
