RCU Forums - View Single Post - Another "I need a car" thread
Thread
02-01-2012 | 10:53 AM
5
kstmRYD
May 2008
415
NYC, NY
RE: Another
I have a brand new Tamiya TA05 ver.II... spankin brand new! Never even seen the floor! Futaba 3PL-2.4Ghz rx/tx brand new! Eagle Racing 60gram Servo brand new! Eagle Racing Shocks new as well, every part is new. The only used parts are the Castle Creation Side Winder and 5700Kv motor. Lots of brand new spare parts come with it too...bulkheads, hubs, wheels... a new set of Raikou D68 tires.. once you use these you will forget about ABS...virtually indestructible
I put in a front one way - rear solid spool - high angle 46mm CVD's and alloy C hubs and Eagle Racing shocks with 3 different spring sets (red,green,blue) and front alloy bulkheads. All manuals and booklets for chassis, ESC/Motor and Radio come with it. The Futaba system alone is still new in the box.
I'm not parting it out...whole thing goes as one!
$285.00 shipped[/size]
great price for chassis, all electronics, radio, esc and motor! on top of that shipped... a steal!
If you want to counter steer it has a 39T pulley in front... all it needs is a 16T front center and 22T front rear with a 36T pulley on rear spool and you have 1.5CS or
40T/16T front and 22T/30T rear and you have 1.8CS...ratios are endless or you can just leave it as is if your new to drifting
RAIKOU D68 TIRES
Eagle Racing 46mm high angle CVD's installed with alloy C hub that gives it plenty of clearance for wild steering mods.
FUTABA 3PL Rx/Tx spankin brand new in the box...never ever used!
Reply
Like
kstmRYD
View Public Profile
Send a private message to kstmRYD
Find More Posts by kstmRYD
View iTrader Profile
