RCU Forums - View Single Post - Elvons-throw on Rookie
Old 08-27-2003 | 10:53 PM
Gandalv
Default Elvons-throw on Rookie
Hello Vin..
Thanks or your reply :-)
About the throws on the rudder, I have set "all there is" in the radio to max: endpoint, dual-rate. Still I cant get 35mm unless I´m using the lowest hole (and I will try to avoid that, the further out on the arm the better I think).
Only solusion I can think of is to offset the servo horn so that it gives more "up-throw" on the rudder, I will try that tomrrow, maybee it helps ? But then again that might give me some problem of getting the two rudder on the same wing to move together ?
Thanks.
Andre
