Elvons-throw on Rookie
Perhaps your servos are mounted wrong. I had this same problem. I had mounted the servos with the arms closest to the trailing edge (to make the linkages as short as possible), and couldn't get enough travel. I turned the servos around (JR 8411's), so the arms exit closer to the leading edge, and now get plenty of travel in the top hole on the elevon horn.
