RE: Novak Smart Stop 2s Voltage Cut-Off Too Low?
Keep in mind that the voltage cutoff triggers when the battery is under load. Once the draw stops, the battery voltage will jump back up. As long as you don't drop the battery under 3.0 volts per cell resting, you will be able to charge it on any lipo charger. I'm not saying that is the best way to treat your battery but with batteries only costing 8-10 bucks, I wouldn't even be concerned about longevity. Use it up for the 20-30 cycles you will get and throw it away!
