RE: Novak Smart Stop 2s Voltage Cut-Off Too Low?
How much volts does it jump back up to though? Im not comfortable letting my lipos drop below 3.3 volts. If it has a resting voltage of at least that than id be fine with it. Its my fault for not looking at the smart stop specs before i bought it. I was just assuming that if its a lipo cut-off than it should cut-off at the safe voltage rate. Its also called a "smart stop", but its not smart enough if it lets the voltage go too low.
