RCU Forums - View Single Post - SwitchGloPro & programming mixes
Old 02-02-2012 | 05:43 PM
mmiller1
My Feedback: (75)
Default SwitchGloPro & programming mixes
I recently purchased a SwitchGlo Pro on-board glow igniter. At present I have this unit plugged into CH7 on the Rx. On the Tx, under Aux I assigned Switch H. When I flip switch H, the glow ignites and the buzzer sounds....as it should. However, I do not want the glow ignited via the battery continuously. They told me I need to do a throttle/aux mix.
I went to screen #2 (Mixes) and under Program 1 I changed the functions to read Master: throttle Slave: Aux 1 (there are only two choices here Aux 1 and Aux 2). What I want to accomplish is this: idle throttle up to about 25% igniter should be on after 25% the igniter should be off, thus saving battery life. Well, I tried following what I thought was a logical sequence, but it did not work. I would appreciate any help in getting this mix working. The manual does not cover on-board glow functions. I know I am probably missing something simple. The guys at SwitchGlo claims this will work but were unfamiliar with the 9CAP. Help!
Tim in Tacoma
