RCU Forums - View Single Post - Bifurcated pipe thrust loss
Old 02-02-2012 | 06:07 PM
sskianpour
Default RE: Bifurcated pipe thrust loss
Shaun,
it's unfortunately not as simple as that. I have gotten to know you over time and understand that you are articulate and intellectual. However no amount of prior "knowledge" actually prepares most jet pilots for flying at altitude. Maybe you have flown at altitude, I don't know. But George has nailed it on the head. What most people fail to appreciate is that this isn't just 20% loss of thrust, it's also thinner air....MUCH thinner air up here.
Up here, Jets don't climb out as well, they don't stay up as well, and they like to fall out of the sky. This is why homeruns travel such legendary distances at Coors Field. It is why golfers always marvel at the added distance the ball travels when they swing up here. Thin air = no resistance. Problem is, we WANT resistance, we count on that resistance that nice thick air provides to give our wings something to climb on. Nice thick air down at sea level makes for nice slow landings, nice stable takeoffs, and lots more gliding and predictable approaches. It may limit top speed more too but you get added thrust to combat that.
The last Best in the West that was held in Colorado before being moved to Cali was held at George and my flight site: Chatfield State Park. We have a 650 foot main runway. Bob Violett came out for it and among other jets, he brought one of his p-70/80 powered Mig 15's. The problem he experienced is very common up here:
1. You back off throttle to slow your plane down and set up for landing. You drop gear and set up flaps.
2. Problem is the plane isnt slowing down like you are used to it doing. The air is thin, the flaps aren't really biting into the air, and the wings aren't really floating on that thin air well
3. Your plane starts sinking MUCH faster than you are used to seeing. Trouble.
4. Predictably, you increase throttle to stop the plane from sinking. You realize that the plane has stopped sinking, but is now going 20-25 mph faster than you are used to when landing. Oddly enough however, you notice you are at a much higher throttle setting than you are used to for plain old straight and level "slow flight", that's because you have about 20% less thrust remember?
5. You start realizing that this isn't San Diego or Florida. It is not a municipal airport with a 1.3 mile runway and nice thick air. You are trying to crash land a now seemingly under-powered jet, onto what looks like a postage stamp of a runway, while coming in faster than you have ever landed, and feeling like your control throws are less responsive than ever before.
6. That nauseating feeling in the pit of your stomach is your realization that if you get LUCKY, REALLY REALLY LUCKY, due to your much higher approach speed, and unpredictability as to how your plane is sinking, you MIGHT get to touch down at the mid-point of the runway, and then have about 300 feet to come to a full stop while traveling 80-85 MPH on touch-down.
7. Bob Violett went around 3 times. He landed on the 3rd. He went long. Tore his gear out. Many spectators children still remember the endless stream of holy prophecies that he uttered as he brought his mangled plane back from 75 feet past the runway.
He swore he would never return. He never did. Welcome my friend, to high altitude flying... When we make trips for jet events to sea-level places, it feels like we are flying in jello. Everything slows down and planes actually WANT to stay up in the air...we often wonder how most sea-level people would do at our fields, since it seems so much easier to fly at their fields...but it's not polite to say anything, and we often don't.
So Shaun, buddy, when George says P-80SE is not enough, considering he has been flying and building jets for 20 years - all while living at 5400 feet- he doesnt mean it wouldnt fly your plane down in San Diego, he means it isnt really doing the trick up here. Apples to Oranges.
(P80) 22lb thrust at sea level - 25% thrust (20% for altitude + minimum 5% for bifurcated pipe) = 16.5 lbs
Would you want to fly an F15 with thrust comparable to a P60 or Wren 54 at sea level....? in a place where there is no lift, no glide coefficient, and on a 650' runway? That's what it equates to up here...
Cheers bud,
Shaz
