RCU Forums - View Single Post - Novak Smart Stop 2s Voltage Cut-Off Too Low?
Old 02-03-2012 | 06:59 AM
w0mbat's Avatar
w0mbat
Default RE: Novak Smart Stop 2s Voltage Cut-Off Too Low?
Voltage cut-offs are only there for protection. They are only intended to stop the discharge of your battery before it gets so low that it can no longer be charged. You are better off just picking the amount of time you want to run for and size your batteries from there. I don't see anything wrong with using 8000mAh batteries - as long as they will fit.
