RE: Skybolt hangar and clubhouse
Ha, that's where I saw the servos on top, plus I was looking at the plan view and saw the single aileron servo on top. I see where they are normally mounted on the bottom, and haven't gotten to that yet.
I had a heck of a time getting the bottom wing lined up. It wanted to be more forward than it should be. I had to jigger the ends of the interplane wires a bit and also sand a little off the leading edge. Then I laid it straight on the plans and put the dihedral braces in and glue it together. Then I trial fitted it and it is OK now. It was a scary time for a while. I see why Zor waited to close in the front end! I think I will be OK. The incidence seems reasonably OK but I'll recheck it and tweak things when it is done if I need to.
