RCU Forums - View Single Post - engine question
Old 02-04-2012 | 04:37 AM
earlwb's Avatar
earlwb
Default RE: engine question
Actually the condensor is connected to ground or common through the engine's backplate mounting screw that goes through the firewall.
They should have shown the booster battery used to get it started as well. They usually used a larger booster battery to hook up in parallel with the onboard two penlight battery cells, for starting the engine. Once started they disconnected the larger booster battery pack.
