RCU Forums - View Single Post - Anybody ever run the OS 77VR as a pattern engine?
Old 02-04-2012 | 07:23 PM
lfinney
My Feedback: (44)
Default RE: Anybody ever run the OS 77VR as a pattern engine?
actually using the smaller carb with a macs quiet pipe set long would actually work well, the quiet pipe has enough back pressure to use the longer exhaust duration on the vr77... a 11x10 or 11x11 or a 12x9 would give some serious performance. no its not the normal pattern setup, but the smaller carb will throttle well with the above props as long as you use a pipe with more back pressure.
a examination of the helicopter engines used today will show that they generate huge torque with 10-11 MM.5 carbs and have good throttle response.
