RE: Basic Right Thrust & Down Thrust Question ???
There is no difference between a slightly hopped up motor or aslightly bigger motor..The airiplane needs 2 degrees down and 2 degrees right thrust if thats what the plans call for..You can adjust from there if nec but you probably won't need to...
