RCU Forums - View Single Post - Sig Rascal 110
Old 02-06-2012 | 04:15 AM
  #606
Zippi's Avatar
Zippi
My Feedback: (10)
Default RE: Sig Rascal 110
ORIGINAL: captinjohn
Zipp[, we are still in Florida....nice warm weather too. Did you get the heavy hub to correct the balance? Capt,n[img][/img]
No need for one. I have my ignition and battery next to the firewall. My onboard battery will be under the instrument panel. I have a switch on both sides of the fuse in line with the instrument panel. Same setup as last Rascal so I hope it comes out ok. If I get some warmer weather I'll take it outside and put it together and check the CG.
Are you in Florida for good now? You've been there for a while.
