Anyone seen a fourstroke that eats pushrods?
Bent pushrod? Happens. Doubt the tappet could grind down that fast. But I have had a bent push rod and the symptoms are as you state. I think it happened from overrevving the engine. If its under warrenty you probably are required to send it in for service.
