RE: High wing incidence
I would start with zero. You can always add it if needed. Generally fully symmetrical models are set up 0-0-0. One question, why the NACA 0012? It will be hard to slow down, have a relatively high stall speed, and be fast. If you keep the weight down and the area up, probably no problem. Just keep these things in mind.
