RCU Forums - View Single Post - Phoenix 6 - Start # 2
Old 02-06-2012 | 01:43 PM
  #238
crankpin
My Feedback: (15)
Default RE: Phoenix 6 - Start # 2
Major masking job for just one stripe, then two stripes, more take off, mask, etc. No problem. This is just a prelude, a start of stripe, design. You can see the blue at top of fuse is flat after sanding, after each color, you wet sand the ridges off. This will all turn to nice gloss after final coat of clear. Bottom will be red and more striping, leave about 1.5" white, horizontal down middle of fuse. This stripe was to go all the way to the nose, I have a different idea here, need to accent the yellow at different areas. The paint will flow from bottom of fuse, into the wing, same colors, after this, copy to stab. It has been raining for days, I paint outside, keep dehumidifier running in the shop, keeps all electronics, engines, etc., dry. Back to this when we get some sunshine.
Crank
Upload success, all below
