RCU Forums - View Single Post - Measure the length of a pattern plane
Old 02-06-2012 | 03:23 PM
nonstoprc's Avatar
nonstoprc
My Feedback: (90)
Default Measure the length of a pattern plane
I was measuring the length of passport and found that I need to raise the tail wheel a couple inches off the ground to get the shortest length. Otherwise, the total length is longer. This is because the trailing edge of the rudder has a curve and the stick-out point is at the top.
So the question. Is the length of a pattern plane the length when all wheels are on the ground, or the shortest possible length after the tail is raised?
