Anyone seen a fourstroke that eats pushrods?
The lift is pretty much the same on both lobes so with the plug out turn the moter over slowly the. the valves should open the same amount with the valves at the proper clearance. Also the pushrods should be the same length. Are there any metal particles around the bottom of the questionable pushrod?
