RE: Phoenix 6 - Start # 2
It worked. Explained above. We are having monsoon's here. Masked off today for red bottom. There are two breaks for the red at the wing saddle. I will try to incorporate these on each side, flow into the wing. More yellow, may use it on the leading edge's. Get the red on, take off tape, then study more on stab top and bottom. As posted, you can see the blue is flat here, wet sanded out. After all color, wet sand, ready for clear. Could the yellow split stripe have run all the way to nose or front of canopy edge ? Yes, except I had something else in mind, all will flow and work out when finished. As can be seen, the masking for the red was done after these shots. Pictures a little fuzzy, forgot to push the macro button. Getting anxious to build a wood kit, this may be my last glass and foam bird. I have unloaded many of them in the last year. Few more here.
2-8-12 - Shot the red for bottom of fuselage. Leave most of paper on, have to shoot the canopy final. Wet sand, mask again for a stripe above the red, need accent. Doxilia clued me in on some overlay re-paint, back to this next week, maybe, travel weekend coming up. With all the rain we have been having, grass is up to my knees, I have plenty of it, fronds on the palms need attention.
Crank
