ORIGINAL: Jorge Obama
Six is enough,other subfunctions will affect the flying sometimes
How so?
7 is the minimum you will want if you plan on getting into nitro because you will want an rpm governor at some point if you stick with it.
Add flybarless and they use two channels for gain one for the tail gyro and one for the head.
Get into scale and your options are limited only by your radio, budget, and imagination.
