RE: Exploded view Webra Record diesel
Please post an image of what you need.
If you have everything but the actual needle then just trial fit a piece of music wire and make a tapered tip on it. The hard part will be to make the threads on the brass part, they are usually a fine thread. The needle on the engine above is the standard needle of the time, so it is the same as on their larger engines.
